This update adds some additional low-bit-depth choices to several file types (PNG, BMP, TIFF), and fixes some bugs. I should be able to do a final release of this soon!
You can also download and install this update directly from the post on the forum.
Changes since 4.2.12:
- New: Added 2-bit per pixel support when saving as PNG
- New: Added 1-bit per pixel support when saving as PNG, BMP, and TIFF
- Fixed low-bit-depth saving quality (8-bit, etc.), as it would sometimes produce very bad results (e.g. only using 64 colors instead of 256)
- Fixed: Sometimes recently saved images would not have an updated thumbnail in File Explorer unless/until its window was manually refreshed
- Fixed: Sometimes saving an image to a network share on a non-Windows server (e.g. Linux) would not work
- Updated bundled DDSFileTypePlus plugin to version 1.10.4.0, which fixes an issue when loading and saving images using the sRGB color space. This issue was reported here: https://forums.getpaint.net/topic/116572-dds-file-format-bc1-bc7-srgb-export-incorrectly. Thanks @null54!
Enjoy!
Dear Rick,
Did you notice my recent comment about a possible bug in PDN over at https://blog.getpaint.net/2020/05/29/paint-net-4-2-12-is-now-available/#comment-21510 ?
Your valuable expert reply would be greatly appreciated!
Stay healthy,
Martin
That’s something that gets reported every so often. It’s not really a bug — the conversion between HSV and RGB just isn’t exact or invertible. Maybe you can find earlier discussions by searching for HSV off-by-1 or something.
Thanks a lot for the hint and also first details, Rick!
P. S.: Please allow for comment editing/removal, at least for logged in/registered users.
Merci pour vos astuces. Jacques
Le sam. 11 juil. 2020 à 19:57, paint.net blog a écrit :
> Rick Brewster posted: “This update adds some additional low-bit-depth > choices to several file types (PNG, BMP, TIFF, TGA), and fixes some bugs. I > should be able to do a final release of this soon! To get this update, make > sure you have “Also check for pre-release (beta) v” >
There are two problems that I have with Paint.Net:
1) The lasso selection tool is inconvenient. Most other image editing programs continue the selection in a straight line when the button is lifted, which allows for more precision and less errors from finger/hand fatigue when trying to select a long outline. Some even allow partial unto of the last click.
2) The text is not editable. Many times I would detect a spelling mistake only after committing the changes and need to start anew. Writing in a text editor and then pasting and correcting the layout makes for a convoluted workflow.
I would appreciate those issues being addressed in a future release.
Thank you,
Alex.
Hi, i really use this app, but can you add an option for edit .tga images, i have some errors when i try to edit these type of files, thanks a lot
Paint.NET already natively supports TGA images. If you’re having trouble with a specific TGA, then either it isn’t actually a TGA, or you can make a post on the forum in the Troubleshooting section and we’ll look into it. Please include a copy of an image that isn’t working.
