This update improves legacy plugin compatibility and fixes an issue with the Effects and Adjustments menus.
Also, the legacy plugin cache has been disabled for now due to a security concern. You can enable it by setting the following registry key to "true": HKEY_LOCAL_MACHINE \ Software \ paint.net \ "Plugins/EnablePatchedAssemblyCache". This is only necessary if you feel like the app starts way too slow, and you have several legacy plugins installed.
Get the update
For direct download links, please visit the forum.
Changes since 4.3 alpha build 7904:
- Fixed compatibility with Shape3D v1.2.6.3 plugin
- Fixed compatibility with FileType plugins that use OptionBasedLibrary, such as ImPDF.Open.FileType and ImPS,EPS,AI.Open.FileType
- Fixed an issue where the Effects or Adjustments menus would be blank, and keyboard shortcuts for adjustments would crash the app
3 thoughts on “paint.net 4.3 alpha (build 7906)”
Comments are closed.
