paint.net 4.3 alpha (build 7879)
This build isn’t too exciting, fresh off the heels of yesterday’s 4.3 alpha build 7878, but it’s important: it fixes a crash when running an effect with a selection active! (unless the selection was just simple rectangles)
For direct download links, please visit the forum.
Changes since 4.3 alpha build 7878:
  • Fixed a crash when running an effect while a non-pixelated selection (not just simple rectangles) was active
The complete list of changes so far for 4.3, as compared to 4.2.16:
  • New: The app has been migrated to .NET 5, and performance has been greatly improved as a result.
  • New: ARM64 is now natively supported
  • Installation is much faster now due to no longer needing the "Optimizing performance for your system" stage (NGEN has been replaced with ReadyToRun via crossgen).
  • Portable ZIPs are now officially available, utilizing self-contained deployment, and do not require the installation of .NET 5. You must manually update to newer versions of the app, however.
  • Improved performance of most effects and other compute-intensive tasks by about 20% on average, due to .NET 5’s improved code generation
  • Improved: Many areas of the app have been optimized to use SIMD (SSE2/3/4.1, AVX2) on x86/x64
    • Drawing on an image with a large number of layers is faster
    • Drawing with the Gradient Tool’s alpha mode is faster
    • Drawing with the Recolor tool is faster
    • Drawing with the Erase or Clone Stamp tool is faster when using a color whose alpha value is less than 255
    • Drawing with the Overwrite blend mode is faster
    • Drawing with the Shapes tool is faster, due to improved compositing performance
    • Drawing with a brush tool without antialiasing is faster
    • Tile compression has lower overhead due to being optimized for SSE2 and AVX2
    • Working with complex selections is faster
    • Many other optimizations all throughout the application and rendering engine
  • Improved: Selection antialiasing quality is now better by way of using a 4×4 super sampling filter instead of 3×3. The code has also been optimized to use SSSE3 on x86/x64.
  • Improved: Performance should be significantly better on systems without HyperThreading (by reserving 1 core for the UI), and also a bit better on systems with it (by utilizing more of the logical cores)
  • Improved: Effect and File Type plugins can now be organized into folders — the plugin loader will recursively search for DLLs up to 1 folder deep
  • Fixed a bug in Polar Inversion that was causing hangs
  • Improved performance of Polar Inversion by 3x, due to the aforementioned bug fix (and a little bit is due to .NET 5)
  • Fixed: There were some issues with zooming in/out using the keyboard, where the anchoring (centering) point was not calculated correctly, causing the canvas to drift in the wrong direction.
  • Fixed a bug when saving with "Auto Detect" bit-depth that was causing fidelity loss on some images that already had 256 colors or less. This was reported here: https://forums.getpaint.net/topic/118401-images-already-with-256-or-fewer-colors-being-dithered-when-saved-with-palette/
  • Changed: A processor that supports SSSE3 (yes 3 S’s) is now required for x86/x64 systems (previously only SSE2 was required). All CPUs released since about 2006 (e.g. Core 2 Duo) support this.
  • Known Issue: Due to crashing, GPU accelerated effects (Gaussian Blur, Motion Blur, Radial Blur) on ARM64 will actually use the CPU for rendering.
  • Updated the built-in AvifFileType plugin to v1.1.13.0 (courtesy of @null54). See the project’s GitHub Releases page for more information.
3 thoughts on “paint.net 4.3 alpha (build 7879)
  1. Confidential Blogger says:
    Confidential Blogger's avatar
    Man… so many improvements. It’s a joy to read them.
    You know the one feature I wish I had the most? Guides and things to which selected pixels could snap. But don’t think about it. It’s above this app’s single-dev level. (Otherwise, I’d have submitted a feature request in the forum.) I’ll make do with zooming and what-not.
Comments are closed.
