Paint.NET Forums and Plugin spotlight: Shapes 3D
I’m hoping this will be the first of many “spotlight” blog posts. I think the forums have become, interestingly enough, an integral feature of Paint.NET (“Web 2.0 meets Desktop 2.0?”), where a large selection of user-generated tutorials and plugins have been made available for free. Free is always good, and can do amazing things for the virality of your product (yes, virality, not “virility”, although in this case the two are kind of related. And no I’m not sure if it’s even a word).
This first spotlight will be on a plugin that was just published yesterday by a new forum member, “MKT”. It is called Shapes 3D and has the most complicated user interface I’ve seen to date in a plugin:
Despite this complexity, and the fact that it’s in Japanese, it has quickly soared in popularity and already has 5 pages of responses. Everyone seems very excited about this plugin, and my hope is that it will inspire other new plugins and tutorials.
I can’t read kanji, but I played around a bit and was able to make the following based on a photo of Mandy Moore:
Pretty cool for about 30 seconds of “work”. You can get the Shapes3D plugin at the forum here: http://paintdotnet.12.forumer.com/viewtopic.php?t=5271&postdays=0&postorder=asc&start=0 . When combined with other plugins, such as Drop Shadow or the Object Reflections, this makes it very easy to do things like software boxes or other perspective-based designs.
9 thoughts on “Paint.NET Forums and Plugin spotlight: Shapes 3D
  1. PineappleQc says:
    PineappleQc's avatar
    Yeah, things like Conditional Hue/Saturation will bring loads of people and make a good name for PdN.
  2. TJ says:
    TJ's avatar
    Can i get virus, trojan, spyware and adware by simply downloading those plug-ins in the forum?
  3. Rick Brewster says:
    Rick Brewster's avatar
    TJ, in generally I don’t believe you will find any problems with the plugins from the forum. If a plugin had anything like this you would quickly see many very angry comments written against the plugin author.
    However, right now plugins are not sandboxed, so I still highly recommend you have standard security software installed (antivirus, antispyware, etc.)
  4. Julian says:
    Julian's avatar
    I was curious if you created this image using the 3-D feature. I was trying to figure how spacing is done when the image is created?
Comments are closed.
