This build fixes 2 more bugs that were present in builds 7916 and 7917.
Get the update
For direct download links, please visit the forum.
Changes since 4.3 alpha build 7917:
- Fixed a bug in the FileType plugin loader that resulted in any attempt to open or save images to crash the app. This would happen if a plugin existed with types decorated with attributes from assemblies that did not exist (e.g. from a unit testing framework).
- Fixed a bug with tool cursors not switching to their "mouse down" forms
One thought on “paint.net 4.3 alpha (build 7918)”
Comments are closed.
