This build fixes 3 bugs that were present in yesterday’s build 7916.
Get the update
For direct download links, please visit the forum.
Note that the offline installer may still need to download some prerequisites if you’re on a Windows 7 or 8.1 machine that is not up-to-date via Windows Update. You do not need to have .NET installed, as these builds use self-contained deployment.
Changes since 4.3 alpha build 7916:
- Fixed a rendering issue with the brush tools, reported here: https://forums.getpaint.net/topic/118596-paintnet-43-alpha-build-7916/?do=findComment&comment=586025
- Fixed an issue that caused the Plugin Browser plugin to crash for shimmed plugins because the Assembly’s Location was empty
- Fixed an issue with tolerance values being scaled slightly wrong for the Magic Wand, Paint Bucket, and Recolor tools, causing discrepancies with previous versions (4.2.16 and earlier), which was reported here: https://forums.getpaint.net/topic/118565-paintnet-43-alpha-build-7906/?do=findComment&comment=585879
3 thoughts on “paint.net 4.3 alpha (build 7917)”
Comments are closed.
