This is a hotfix for 4.3 alpha build 4894, which was published yesterday.
Get the update
For direct download links, please visit the forum.
Changes since 4.3 alpha build 4894:
- Fixed the Magic Wand tool producing glitchy results when used with a combine mode
- Fixed the PluginSupportInfoAttribute’s properties being read-only
Awesome, I needed this. I can’t wait for you guys to implement anchoring so it’s easier to allign objects. Keep up the incredible work!!.
