This should fix the 2 big crashes that people have been reporting.
To get this update, make sure you have "Also check for pre-release (beta) versions" enabled in Settings, and then click on the Check Now button. (Unfortunately alpha/beta releases are not currently available for the Microsoft Store version of the app.
You can also download directly: https://github.com/paintdotnet/release/releases/download/4.206.7256.6914/paint.net.4.206.7256.6914.install.zip
Forum discussion is here: https://forums.getpaint.net/topic/115494-paintnet-426-alpha-build-7256/
Changes since 4.2.6 alpha build 7254:
- Fixed the crash when using pointer devices for drawing. This also affected mouse drawing when the app’s DPI didn’t match the monitor’s DPI.
- Fixed the crash when saving an image and dismissing the Save Configuration dialog before it could draw anything (e.g. by pressing Enter)
One thought on “paint.net 4.2.6 alpha build 7256”
Comments are closed.
