This is a small update that improves some quality-of-life issues, and fixes some important crashes due to mishandling of some non-fatal DirectX errors.
You can also download and install this build directly on the forum.
Changes since 4.2.14:
- New: "Tolerance Alpha Mode" toggle button added to the toolbar for the Magic Wand, Paint Bucket, and Recolor tools. This permits switching the algorithm for color comparison between premultiplied (default) and straight. "Straight" will distinguish between transparent pixels with different color values, whereas premultiplied will see them as equivalent.
- New: Holding Ctrl while using the Color Picker tool will sample from the merged image (vs. just the current layer)
- New: The file name in the title bar will now have a prepended asterisk when it has unsaved changes
- Changed: The image close ‘X’ button can now be clicked for images that are not currently active
- Fixed: The Rectangle Select tool, when used to draw a constrained, fixed ratio, or fixed size selection, will now correctly clamp the rectangle to be within the canvas
- Fixed: Layers -> Move Layer Up/Down/Top/Bottom was not working for images with fewer than 3 layers
- Fixed: Edit -> Erase Selection will now fill with transparent black (#00000000) instead of transparent white (#00FFFFFF)
- Fixed: Custom Shapes will now be displayed in a consistently sorted order
- Fixed: ".pdnSave" ghost files should no longer linger when saving to the desktop. This was due to a bug in Windows and File Explorer.
- Fixed crashes due to DXGI/Direct3D "lost device" or "device removed" errors that can happen for various reasons (dock/undock, driver update, low memory, etc.)
- New: Plugins can now use the IArrayPoolService, a wrapper around .NET’s ArrayPool, to optimize their array allocations
- Updated bundled AVIF FileType to v1.1.6. See the pdn-avif releases page on GitHub (https://github.com/0xC0000054/pdn-avif/releases) for more information.
Enjoy!
You should add a auto save
You should add a auto save!!! Please add it !!!1
You should add a selection tool by line segments as GIMP where you click over an image to construct a irregular polygon to select a portion of image.
For me (and i believe it is for many others), it is essential.
You also should invest your programming time over Text Toll … including outline function for instance. Or arch texts …
And also, you could think about transformation over images (or part of them) as perspective. At this time some plugins deal with it poorly.
“New: “Tolerance Alpha Mode” toggle button added to the toolbar for the Magic Wand, Paint Bucket, and Recolor tools. This permits switching the algorithm for color comparison between premultiplied (default) and straight. “Straight” will distinguish between transparent pixels with different color values, whereas premultiplied will see them as equivalent.”
“Fixed: Edit -> Erase Selection will now fill with transparent black (#00000000) instead of transparent white (#00FFFFFF)”
LET’S GOOOOOOOOOOOOOOOOO
