I haven’t been working on Paint.NET v4.0 at all lately, but I have been reading, learning, and prototyping about a whole sleuth of things related to functional and asynchronous programming. One such topic is that of monads, which I have a blog entry almost completed on. However, I wanted to get a quick blog post to show something simple yet powerful. LINQ brings a lot of power to IEnumerable<T>, and in this case we’re going to map the console input into an IEnumerable<T>. Then we’ll use standard LINQ methods to only display those lines of text that have ".dll" in them. It’s a contrived example, but it’s easy enough to find more useful applications of this. I have to go in a minute, so I’ll throw this code up on the blog and let the conversation be driven from the comments.
public static class Extensions
public static IEnumerable<T> ToList<T>(this Func<T> sampleFn)
while (true)
T val = sampleFn();
yield val;
}public static IEnumerable<T> While<T>(this IEnumerable<T> list, Func<T, bool> whileFn)
foreach (T item in list)
if (whileFn(item))
yield return item;
else
yield break;
}public static void Execute<T>(this IEnumerable<T> list)
foreach (T item in list) { }
}public static IEnumerable<T> Do<T>(this IEnumerable<T> list, Action<T> action)
action(item);
yield item;
}class Program
public static void Main()
Func<string> inputSampleFn = Console.ReadLine;var input = inputSampleFn.ToList()
.While(s => s != null);var query = input.Select(s => s.ToLower())
.Where(s => s.Contains(".dll"));query.Do(s => Console.WriteLine(s))
.Execute();
Now, compile this to something like "dllFilter.exe". Then run, at the command line, "dir c:\windows | filter.exe". Neat π
